Safe voltage to OC an E6600
Darlok
Hey what's the suggested voltage and the max voltage i can pump to Oc a Conroe E6600 and have it 3D stable? .. I just bought mine and waiting for a tower before i assemble it.. I'm new to overclocking.
THanks
Under 1.6v should be ok if you can keep temperatures at bay. I had to turn to water to run more than 1.4v though since on air, it was getting too hot.
At around 1.45v and 8x450=3600 for my e6400, water keeps it at about 60'c coretemp under load.
If you're new you should keep it under 1.45, on stock cooling try not too go more than .5 above stock, or see how far you can go on stock and leave it there.
Yeah, 1.45 is a reasonable max to limit yourself to at this point.
Just how far are you looking to overclock anyway?
If only say 3.2 is your goal, you should be able to achieve that with probably around 1.3v actual load voltage. It'd probably be about 1.375v or so set in bios, depending. From that point on, usually it's a much higher slope. At 1.3v, it runs pretty cool. Even with stock cooler, I was only seeing in the low-mid 60's. Stepping up to an arctic freezer, I saw in the mid 50's. With water, it was down in the mid 40's.
Going higher on the other hand, on the general, like said is a much higher slope to be climbing. I need to raise from 1.3v to roughly 1.4v to be stable at 3.5 and 1.45 to be stable at 3.6. At 1.45 and 3.6, even with water, I'm seeing about 60'c under load (around 15'c increase from 3.2 and 1.3v)
1.55 should be the maximum (by Intel)
1.6 Is too much
1.5 Is very high
1.45 is a good limit for now (as others said)
Keep an eye on the temperatures.....Keep them under 60-65c during load!
