I've looked around to try and find out what the optimal temps on a video card would be. I'm getting mixed results, so I think it would be best to just ask you guys.
My card: eVGA GeForce 7900GS
Idle, the nvidia tool reported a temperature of 57-60* C. This was with the stock Heatsink/fan. I unplugged the noisy fan and tossed a little 80mm case fan in there, and now my temps are 61-62.
I don't do anything resource intensive enough for these temps to go up too much higher (usually below 70*), so that's pretty much the ceiling.
How are those temps? Should I be worried?
I plan on modding the panel of my case and tossing in two 120mm fans, so if these temps aren't too bad, this will certainly make things better.
What do you think?
What do you think?
