Chrisroman
- May 29, 2011
I picked up one of these to vent into one of these
Plan is attach the cold air duct from the AC directly to an intake on the HafX, either side panel or bottom front intake.
I'm assuming that since this AC unit was designed to do exactly what I'm planning to do, that it should be safe, but I've been told that AC units can create condensation/moisture in a PC. I contacted the manufacturer, and they say the moisture is vented out the exhaust hose, not through the cold air duct.
But I'm curious if anyone has used one of these units in a server environment with the spot cooling feature? Any issues with moisture/condensation?
