Safe to use ancient thermal paste?
NickN
I found an old tube of Arctic Ceramique out in the garage. It must have been sitting there for years because it's been so long since I've done a build with Ceramique. What I want to know is, is it safe to use on a new build considering it's been sitting in the heat of the garage for years? I'm about to put together a new box and I'm finding myself in need of thermal paste. Should I spring for the extra $5 to buy a new tube or can I be a cheapskate and use the old tube? Thanks! :D
The paste and fluid may have separated.
Squeeze a bit out to see.
If it looks uniform throughout and not thick, it should be ok.
Personally I'd get MX-2 as thats what I use now and is also non conductive.
When I used an old tube of Ceramique, I pulled the plunger all the way out and pushed it back in a dozen times to try and remix the paste. It worked fine for me then.
This past weekend I've actually just used a tube of AS5 from a couple years ago. It had one little bubble(gap?) when it was coming out but nothing that wasn't fixable by simply going over again.
Supposedly it's best to store thermal paste tip-down
Ancient thermal paste lol
newly excavated by noted computer historian in silicon valley.
make sure it is not separated, and go ahead. check your temps to verify.
Once the paste is applied, it has to last several years and is subjected to multiple heat cycles and temperature extremes. So, my guess is that it is pretty tough stuff, and will stay relatively stable when sitting in storage.
