icehokplyr
- Oct 9, 2004
Is it safe to overclock my Prescott Pentium 4/3.0E? Its temperature runs at about 49 - 50C.
Any recommendations?
Thanks for any help.
XeRo_Dark said:yes its safe if you go with a diffrent cooling sollution, otherwise with stock cooling at that temperature i wouldnt bother to OC it, even then its 3.0ghz it will already run anything on the market fine, if you really wanted to i guess with your current cooling u should be able to get atleast a 200-500mhz overclock, just to play it safe until u get better cooling then go all out and oc the hell out of it
Sideroxylon said:Check out my sig. With the Koolance I'm at 44c/58c. My only problem now is that my northbridge gets hotter than my cpu and I think it's holding me back some. I can actually get it to boot into Windows at 3.9g but it's very unstable.
Get some decent cooling and that cpu will fly.
Good luck!!!
I may try an AMD. My problem is that my Prescott runs hotter than normal. They all do. I'm seriously thinking about an AMD. Any suggestions out there?
Sc0rched said:Are you trying to say that All prescotts run hotter then AMDs? A little confusing with the wording, but I'll assume that is what you said. I have an FX-51 and 3.2Ghz Prescott. The FX with stock cooling ran at ~40C-53C. The Prescott with stock cooling for me is running at ~36C-48C. Now they are different cases, but the temps seem to be pretty close to the same with stock fan, volts ,etc. Also, are you saying that you are going to sell your prescott setup for an AMD setup? I would seriously reconsider, in games you will see a performance gain, but selling a used prescott, motherboard, etc will lose you some money. In apps, you will lose performance. I say get some better cooling or be satisfied at lower clock speeds. Good cooling can be reused on multiple systems..
