ShiShKaBoB
- Aug 10, 2004
I went searching around on these forums and on google but I couldnt find a straight answer.
I have a MSI K8N Neo2 Platinum that I am priming to get ready for an opteron 165 with a 9X multi. Im in the process of testing my FSB, and Im curious what a safe tempurature is for the chipset. I believe the "local temp" is the chipset temp in "Speedfan". Im currently running my HTT bus at 300Mhz, and my "local temp" is running at 39-41C at idle, and 51-52c max under load(so far).. I curious if running 52C on a chipset for a 24 hour period is safe? (I dont plan on running it 24hours under load, but if I had to would it be safe.
Based on your experiences and knowledge what is a "safe temp" on the nforce 3 Ultra chipset?
Also what is a good software application that will monitor (as accuratly as possible) my system temps? (I have MBM5, and Speed Fan). Thanks.
P.S. I've already took off the chipset fan/heatsink, wiped off the junk that was on there, and applied AS5.
