Safe PWM temps
kaiweiler
Hey what would I try to keep my PWM temps under on an Abit IP35-Pro?
My PWM is currently quite a bit higher then I am used to seeing and I'm wondering what the safe zone is.
Thanks
Thanks
These PWM's are built to take alot of heat abuse something like 80+C but for me anything above low 40sC idle regardless of overclock is too much. Do an internet search for PWM bolt mod there's a couple guides to do it it's really easy and brought down my idle on a 3.4ghz Q6600 to 34C and 58C load.
