SearchForTheAnyKey
- Feb 28, 2004
From what I've read, it seems that the best HSF's out there are the ones like the Swiftec and Zalman high-end offerings. The only problem is that moving your case once you have one of these bad boys installed is a tad dangerous.
I'm going to have to take my comp around fairly frequently, usually to the odd LAN, but also on a few cross-country plane flights, and would rather not have to remove the heatsink every time I do. Any suggestions for a heatsink that still gets the job done but won't break your mobo if moved?
