roncomatic
- Jul 29, 2002
Hi, I have a combo USB/firewire card that I installed & connected with internal pinouts to the case's front firewire ports and USB ports. I am sure of correct USB connections, but not 100% sure of the firewire connections... more like 99% sure the connections are correct... and I want to make sure 100% before I hook a camera up to it.
So I was thinking that there might be a Firewire tester available. BTW, I searched the forums, google websites & google newsgroups to see if I could find a link to one before I get lectured about not using google or forums search.
If I can't find one, I suppose I could buy a cheap firewire cable & cut one end off so I can test the voltages of each lead.
thanks
thanks
