Safari responding slowly.
ceejamon
Sarafi recently has been crashing often and responding VERY slowly at times. I have no idea what could be causing this, as it happens even if I reboot and run nothing but Safari. OSX on a G4 Powerbook. Any ideas??? :confused:
How much ram do you have in the PB?
edit: Mine crawls with 1.5GB ram on a Dual 2Ghz :rolleyes:, So its not just you
Empty your cache, clear history, delete prefs, repair disk permissions, run software update and get back to us.
even better...just reset Safari...mind you will won't have your history and if you had saved passwords for websites you will have to rest those but it is very simple....go to the Safari menu and find Reset Safari
I'm using version 10.3.4
I have 1 gig of ram
I'm gonna try resetting Safari.
Come to find out, it was my hard drive causing the problem. My hard drive died on me, it's been replaced, and now Safari is functioning just dandy.
