Sad face:( need help on card inquiry.
Ruhl
I had ordered a new x1950XT card from newegg, and recieved it today. Upon trying to install it, I noticed the card will not fit into my motherboard. The Pci-E slot is to far back, and as thick as the card is, I cannot fit it :(.
Now I have to RMA the card back, but I still want to get a good card but not have to rebuild a new sytem to use one. According to CPU-Z program I have:
AMD Athlon 64 X2 4200+ (2.2) ghz
The motherboard I have is a model C51MCP51. now before I try to get another card I would like to know if it first first.. Is there a way to find out what cards I can use with this mobo? or am I SOL and have to get a new one?
lol, your mobo might be agp and ur card might be pci-e or vice versa check on it. :D
edit: the C51MCP51 is AGP and you might want to get a agp card not a pci-express
do not rma the card as of yet, please take a pic of the mobo in your case that your trying to stick this card in.
i take that back. You're installing the card wrong some way, because if you do have PCIe, it will work, GUARANTEED EVERY TIME. I have yet to see a card so deformed that it would not fit onto a motherboard.
who makes the C51MCP51?
Biostar? Winfast? Foxconn?
What colour is the mobo (if you dont know who makes it)
**EDIT** yeah... You have an AGP board. You can't use your card in an AGP board. You need an AGP video card.
OPTIONS- X1950Pro AGP or 7800GS - is the X1950Pro out yet I can't find it but a lot of people were talking about it there for a while
Or just save money for a new mobo/ system
The CPU-Z program shows the Bios as the motherboard name. this is a common problem with this bios. others are having the same problem. This is a PCI-E board.
http://www.rebelshavenforum.com/sisubb/ultimatebb.php?ubb=get_topic;f=53;t=000141
bios code: C51MCP51-6A61HB09C-00 (nvidia codename is crush51 = C51) This is onboard video.
This is a bios code for a BIOSTAR (and several other brands) TForce6100 Socket 939 NVIDIA GeForce 6100 Micro ATX
http://www.newegg.com/Product/Produ...hInDesc=GeForce6100&Submit=ENE&SubCategory=22
Nvidia GeForce 6100 series.
http://www.nvidia.com/page/gpu_mobo_tech_specs.html
Had to go to Google/to a [H]ard|Forum thread/to another [H]ard|Forum thread/to Newegg.
I will die if I am wrong.
You have a Micro ATX board and this large card is longer than your motherboard. You probably have a Micro case with it and that eliminates the possibility that all high end video cards will fit into the case. Even though this is a modern board, it was designed for the work place. For those that need to type and look at a video display only. The motherboard has on-board AGP video and was made for size and an extremely low price.
But you can still use the X1950XT.
You need to purchase a new case that is an ATX and Micro ATX compatible. There are a ton of them out there for under $50. I would also advise that you upgrade to a ATX motherboard. They can be real inexpensive also.
this reminds me when i was trying to fit an AGP card on a PCI-E board :rolleyes:
but yeah if u want that videocard just get a cheap mobo to replace it, or return it pay 15% restocking fee and get an AGP card.
on the front of my system it say's Pci- Express, so I assumed it was when I bought it.
I had AGP before and the slot does look diffferent, I mean i have a Pci-E card in it right now a 1300 x radeon.
when I try and fit card in though, the case and mobo wont let me do it. but the slot looks like it would fit it
Sounds like you have a Micro ATX case or otherwise a very small case.
Obvious solution, buy yourself a midi tower case that support the ATX standard. All your other hardware should fit in such a case without problem.
EDIT: unless you have a Dell computer, then you are SOL.
if it says PCI-E on the front it MUST be PCI-E
Either it's not lined up correctly or you're trying to force it in there way to hard. Be gentle, line it up perfectly with your eyes and slowly push. Yeah that's obviously common sense but maybe you're a little too excited and seem to be rushing it ;)
Ruhl said:
gateway computer...
just as bad ? :(
Not quite as bad, Gateway use a lot of standard size/connections hardware and if you just get a bigger case there should not be any problem.
Bring your computer with you to the store and let them have a look at it and they will help you find a case that fits.
walwalka said:
which gateway do you have is it one from bestbuy and what is the model number
Yeh I got the GT5032. what seems to happen is, the Pci-e slot looks right but the x1950XT is real thick, the other half of the double wide metal bracket seems to overlap into the metal peice of the motherbaord that you plug the mouse and keyboard into and I can't remove that.
I guess I have to get a pci-E card that has a 1 slot takeup.
well in the Pic, t he Black outline shows the piece that houses the mouse/ KB input on the Mobo.
The red outline basiclly shows where the vid card would go since it's double wide.
index.cgi
oh, well that sucks.. i guess your going to have to change motherboard OR change the videocard to a one slot aka 7900GT or 7950GT.
Thats an fugging odd mainboard :eek: One of thousands reason to not buy OEM Computers.
I haven't been following any links, but from the sounds of things you have a BTX motherboard... good luck fitting any high end card on that board.
EDIT: followed the last link with the image. You have a BTX board. You're SOL, unless you can find a single slot cooling solution for your card, then remove the hold-down bracket and replace it with a single slot one.
Also you won't be able to fit that motherboard into a standard ATX case. You'll have to find a BTX case, and even then you'll still run into the "overlapping" problem.
yeh I have to go wit ha single slot card , like a 7900 gt, 7600 gt etc.
make sure you have enough power.
check the PSU!! also make sure you have free molex x 2 to attach to the pci-e power on the card.
Im not sure what a molex is? But I have a Antec true power PSU 550 watt, I would think that is enough for a 7950 Gt
