pocari1986
- Oct 15, 2007
I'm currently on a A64 3200+ @ 2.4ghz and im wondering if it's worth upgrading to a x2. I see 2 of them on tigerdirect http://www.tigerdirect.ca/applications/category/category_slc.asp?CatId=1948&and am somewhat undecided inbetween the 2.
1. AMD Athlon 64 X2 3800+ Processor - 2.0GHz, 1MB Cache, 1000MHz (2000 MT/s) FSB, Manchester, Dual-Core, Retail, Socket 939, ADA3800BVBOX, Processor for $73.99
2. AMD Athlon 64 X2 4200+ Processor - 2.20GHz, 512KB Cache, 1000MHz (2000 MT/s) FSB, Toledo, Dual-Core, OEM, Socket 939, ADA4200DAA5CD, Processor for $85.99
is it better to go for the 3800+ manchester with the 1mb cache instead? or am i better off not upgrading as the performance gain won't be much?
thanks
thanks
