s939 HSF options?
synaps3
Alright, I have a Micro Fly and I previously was using a TT Blue Orb II. Temps were initially great, idle at 2-3 degrees above room temp, and load never going over 35 degrees. Now, the fan is making clicky noises and temps have risen to 35-36 idle and the noise has doubled. What is my best option for a new heatsink for my Micro Fly? I want something with no lights this time, I am getting really tired of all this stupid lighting and over-modding. I was thinking of the Artic Cooling Freezer 64 Pro (I think that is what it is called), but I do not think it will fit.
Any suggestions are welcome.
I was looking to spend under $40, but it looks good (other than the price). Any other suggestions?
The stock AMD heatsink, that has 4 heatpipes. It uses an 80mm fan for cooling, though I think it's an 80x80x20mm fan though. It appears simple enough to swap for something else however.
It'll cool roughly the same as a Thermalright XP90 (aluminum) and it will generally go for around 18-20 USD.
It also is fairly low profile, as well.
I do not have the stock heatsink, I ordered my proc OEM. Anyone know for a fact that the Arctic Cooling Freezer 64 Pro will or will not fit? It is much cheaper than the Zalmans and seems to be getting much better reviews than my Blue Orb II...
It will not fit as its too tall if it is this one you are on about ->
The Zalman 7700 and 7000 series are both highly regarded
