s7 edge moisture detected
SXT15
I have an s7 edge and everytime I plug my charger in it gives me the moisture detected error. Luckily I have a wireless charger, but am wondering if anyone else has experienced this problem and if so how to fix it.
If you've allowed it to dry out and it still happens, then you should probably contact Samsung directly to send it in.
oem charger or cheapy? try cleaning the contacts maybe? then contact Samsung.
thanks for the response will try leaving it in rice and going from ther
I mean, rice is a hail mary plan anyways, so even if it DID get wet, it might be an issue. Plus, rice needs a few days with the phone off to even start to have any effect.
