I'm in the process of setting up my new rig.
P4 530J 3.0 Gig
XP-120 & panaflo 120mm fan
Asus P5GDC-V
1 gig ram
2 optical Drives 1 DVD R/W, 1 older CD R/W
2 hard drives
1 PCIe video card in a month or so
The computer will be in our bedroom and I would like to keep it as quite as possible.. XP-120 to help keep the noise down.
For some reason I have gravitated to the S12 500 w seasonic PSU. I think partially because of the 120mm fan for quiet operation, it also has 2 or 3 sata power connectors and is PCIe ready (which really means you have to have an adapter taking up 2 4pin molex plugs) I also like that it is in the 80% efficiency range.
I plan on having this setup for the next 3 years or so. So I would rather get something that will meet my needs for the next 3 years. I'm sure this power supply is overkill.
Is there something else that has sata connectors, 120mm fan, PCIe ready that is a little cheaper and more than good enough?
Any thoughts or suggestions appreciated.
P4 530J 3.0 Gig
Asus P5GDC-V
1 gig ram
2 hard drives
