S-Video to coaxial
Alvein
What would be my success rate trying to do this? My video card has S-Video out (and component. No composite, though), and the TV I want to use (an old 24'' one) only has a coaxial input.
I bought this** RF Modulator, but no luck. When I try to detect the devices, only the monitor is listed. There is an option to force the TV detection, but that does not help. Maybe it's not possible? I guess somebody should have tried this before!
10x
**Used cached page because the original one looks messed up for some reason.
dont think its possible. my video card wont output to my television unless i have it connected directly, having even a selector box in the middle has never worked for me
Is what you are saying that the TV is not showing up at all?
It *should*, even if the device isn't working right. What kind of video card are you using? Some older models could not output to two 'analog' devices at the same time.
Otherwise, it should be a simply matter of selecting the second display in Window's display properties and selected 'extend desktop to this display'.
Thanks dudes,
Articles like this one made me buy the modulator with blind eyes. The thing is depicted so easy that I cannot figure why it could be any problem.
I have a MSI 6600GT (AGP version with VIVO, SP edition). I've even forced the TV to be the only output device (you know, my LCD loose the signal after that), but no success.
Just to be sure, I connect card's S-Video Out to modulator's S-Video In; modulator's ToTV coaxial connector to TV; and set the channel to 3 on modulator and TV. Other things remains untouched.
I'm not sure if I should put my TV in Air mode, or Cable STD or Cable HDC. Anyways, none of those modes work. :(
wierd as i can run my GFX through my radioshack RF modulator and it works fine, its just that the text isnt so great on a CRT TV.. should be Cable Standard mode, does it need any power, mine does?
I used a VCR/DVD combo player with a built in modulator to go from S-Vid (and composite video) to TVs. This was using an old laptop, I forget the video card, but it was an nVidia. nVidia's drivers let you adjust the color, center the display, and such.
With the TV's mounted up on a 10 foot ceiling, you couldn't read anything smaller than size 44 font. It worked fine for my purposes though (pictures and announcements at a school).
Alvein said:
Thanks dudes,
Have you tried the latest (4.13) WDM drivers for the VIVO device?
Does the 6600GT work with video-in alright?
