Then you're doing 480p (720x480p).AZBOOSTIN said:NO my tv isnt Hd
no, you can't do that. you are pluggin video cables into audio inputs. The colors are there so you can match them up. You don't have component inputs, you have composite. yellow video, red and white audio. the red/blue/green are all video, no audio.AZBOOSTIN said:I see what you mean but im plugging it in to the right spots... just using white for blue yellow for green and red for red... I jsut didnt know if there was a physical difference in cables??
CrimandEvil said:Svideo is 720x480 interlaced meaning that one line of data is rendered on the TV at a time. Basically it's the lowest you should go for descent video quality.
Component is Progressive meaning that two lines of data are being rendered at a time, this is what a PC moniter does. It can display 720x480 and above in progressive.
Go with component or DVI/HDMI everytime.
Methodical said:for information, component doesn't separate colors.
One of the three cables is Lumi. meaning brightness. If you only plug the lumi cable in, you'll get black and white.
Another is color. Another is sync (i think?).
