S/PDIF Header for Winfast MB
mt_100
I have a Foxconn (Winfast) motherboard that has a S/PDIF output header on it and need to get the port hookup for it. Are those standard?
Anyone know where I can get one?
if you want coax spdif (not optical) all you have to do is find the data pin and ground pin. Hook that up to a rca socket and you're done (might have to experiment to get the polarity right, but it won't kill any equipment if you have it wrong.) optical is a bit more convoluted.
The motherboard has a four pin connector on it with one pin missing and I know the pinout. Was hoping there was a bracket I could get.
I emailed Foxconn so have to wait and see what they say but I know they incluide the adapter with other boards so maybe they sell them as well.
I emailed FoxConn/Winfast and asked for help on locating one. The response I got was outstanding, simply said give us your mailing address and we will send it to you.
