I was checking out my different drives S.M.A.R.T. info using speedfan. I did the online full report option on each one. They were all fine except for one of the Samsung drives. It had this note after the test:
On the "Current Pending Sector" attribute of the chart it just says to "watch" it. It doesn't say it's bad or anything. But then after the chart it has that note. Is there anything I can do to make this better? I searched google for "read/write surface scan" and I couldn't really seem to find anything. The drive seems to be working fine otherwise. Except when I tried to run a chkdsk the event log shows a bunch of read failures in step 4.
Any ideas?
P.S. Would reformatting help at all?
NOTE : your hard disk has 103 pending sectors (this value is very large and your hard disk should be replaced). Those are sectors that couldn't be properly read and that the hard disk logic is waiting for a write operation to try to remap to a spare sector (if available). According to the Reallocated Sector Count attribute, your hard disk seems to have available spare sectors. A simple disk surface scan won't be enough to force the remap operation. You need a read/write surface scan to remap the sector. The best option should be a tool that knows about what should be read from that sector so that it has some option to apply the best fix to the missing data.
Any ideas?
