Ok im stuck with a delima....
The S Flex's claim to be 85cfm @ 37.5dba
Im looking at some San Ace 109 mediums 118cfm @ 48dba
now the specs are close enough to each other that im sure the race will be quite close.
I can get the S flex's for 10$ each and the San Aces for 7$ each.
The Sflex's are NIB and the San Aces are "lightly used"
Both will be on a fan controller and will be set up primarily for a radiator fans (high fpi BIX 240) (need high static pressure)
If i can double it up as a case fan that would be great too.
What do you think i should get? Im looking for a balance between noise/static pressure (and i guess cfm too) and it needs to make no odd noises whatsoever when underolting
