Ryzen 5 2600 SFF cooling
DogsofJune
So I finally found a case for my 2600 gamer. The previous case was some old junky mid tower box I had in storage. Now it's in a SFF Corsair box.
I have the stock cooler on it and it's stayed in the normal temp range for a 2600. 60-70c under load and around 63-65c gaming, but the new box, Cinebench will put that in the 81-82c under load range.
It's the first system I have had in quite a long time that has been over 55c. Most everything I have had idled in the 36-38c range, but this one isn't watercooled.
I am looking for a cooler that is up to 88mm tall, fits an ITX board with Gskill ram tall heatspreaders, and can handle 100w TDP.
I'd like to do an AIO, but the only one I found to fit is tiny. Single 80mm fan and radiator tiny. Craziest little goober I have seen.
So, recommendations?
