JamesfromDFW
- Mar 19, 2016
So I have a GT 1030 2GB not being used..should I go ahead and install it in my new Internet PC or just leave it alone as it is with the 2200 G? TIA(8gb ddr4 installed)
If you plan to OC:
The 2200G can be hard to OC when you are doing DDR4, CPU, and GPU overclocks all at the same time. It can get pretty finicky with the last 100-200mhz or so.
It would be easier to OC the CPU and DDR4 if you didn't have to worry about the IGPU.
That's really the only case I could make for using the GT 1030.
Performance wise, its a wash.
