Rx480 and 6900xt in same setup?
sabrewolf732
Hello,
I mine with nicehash occasionally and have been using an rx480 in my garage which helps keep it warm during the winter as I use it as a gym. Being that it is warming up can I put said rx480 in my main setup as a secondary card and mine while I am gaming on the primary card (5900x, b550, 6900xt, corsair rm850x)? Will I have driver hurdles to jump through?
should work fine, except having a constant ~120watt heat output in your main case there.
Put it in and it works great. Not sure on additional draw as I have the rx480 set to 1GHz core and 1000mv so driver reports 73w usage.
