RX-9 Gaming Case
Well since when is european design good? not that other areas don't have their own design aesthetics, each has pleasing attributes in my eyes. This case and the Asus case remind me of smooth lined cars. the Ferrari Enzo comes to mind, the 360 modena, with the two scoops of the vento. I happen to like the juxtaposition of the angles of the windows and the smooth curves in the front. So some people including me like that looks of that case, where is the issue. so you don't agree, and that means you get to flame. As far as modders not liking plastic? I don't know where that came from. Plastic is difficult to work with if you don't have the correct tools, and so most home modders avoid it, because metal is easier to work with. try vacuum forming a side panel out of plastic on your workbench vs hand forming a metal panel. This case isn't even made out of plastic, it's steel and that is a paint job. I bet that changes some people's minds. the design also uses front mounted speakers, and a top mounted lcd display. You just don't seer them in the picture.
I guess more people just like their aluminum boxes, some of the more highly touted cases around here are just that. I don't find them appealing because it's just a box. If you like them that's fine with me. I've studied design and art for a while now and it just hurts me to see the same tried and true design re-hashed over and over and over. atleast this case is trying something different.
