Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Some components of Wattman won't install properly when AB is present or running.
Uninstall afterburner till after the AMD driver. Check your temperature in Wattman,
which comes with the AMD driver. When all is good, then reinstall your afterburner.
If you aren't having to run pixel patcher to hack your driver to start, then the BIOS of
your AMD still has the original signature.
