Rx 470 8gb xfx code 43
Goorath
Ok lads, let's start with the obvious thing.. BIOS is stock, no signal on any of the outputs.
Gpu chip gets a little warm when plugged in the slot and under juice, after minute of run it burns alille so a turnoff is necessarry.
GPUZ tells 8192Mhz hynix RAM, it reports TMUs, ROPs, shaders but does NOT SHOW memory throughput nor texel/pixel fillrate.
I am thinking of clock generator on the card went bad. Yathink?
Thanx
PS: no short on any rail
Did you just get the card or did the problem just spring up?
Have you verified the ram type by reading the chips?
