RV02, how many 3.5"?
Hi folks
I currently have an old case but it has 4 slots for hard drives, plus I have an adapter for 5.25 slot to fit my SSD in.
I'm looking at buying an RV02, but reading that it only has 3 x 3.5" slots.
Is there an adapter you can buy?
Thanks
Nope, it only has room for 3 drives.
You can fit as many SSDs as you can duct tape/velcro though.
Yeah the RV02-E which amazon and some places have now has the same interior as a FT02, so 5 3.5s and 1 SSD
the rv02 uses a cage that holdes 3x 3.5" hd's. you can purchase a second cage from silverstone to double up. it should be less then $20.
or you can mount directly to the 5.25" bays.
if you have a 2.5" SSD, the RV02 has an ssd mount on the side of the case. In stock form, it holds 1 2.5" + 3 3.5" drives + 5.25" bays.
