RV02-E mod for an H100?
hierovision
Is there an easy mod (I don't own a dremel) to fit an H100 in the RV02-E? Maybe drill mounting holes in the back or something? I'd rather not stick the radiator as my bottom intake and ruin my case thermals...
have you ever thought about joining the ghetto case mod? the more primitive modding, the better...
a set of nibblers
a nail
a hammer
nibble the back area for air flow, then use nail and hammer to tap holes into the proper locations for fastening the radiator...
How does putting the H100 in the bottom ruin your thermals? There's not a gigantic temperature change for the air coming out of a radiator, 5C-10C at most.
Just put your H100's radiator over the rearmost fan such that the air going through it blows to the backside of the GPU. I did that when I had a 240mm radiator in my old FT02.
The "rearmost" fan would be the one below the power supply. If it worked well in an FT02 it would probably work in the RV-02E as well... I'll have to actually measure when I'm ready to purchase. Just gotta sell my old system and then I can actually afford one or the other ;)
