Rut Roh! I need help!
SithSolo1
Ok. Just finished putting my system together and I booted but I got no video signal...
Antec P160
Antec True380
brand new barton 2500+
(2) 256MB sticks of Mushkin Black Level 2 PC3500
Radeon 8500
Shuttle AN35N-Ultra
250GB HD
reset the bios and rebooted with both sticks of ram, the cpu, and the video card. I have video now but it says the CPU is an XP 1100mhz and the memory frquency is 400mhz. Which says to me that the FSB is set to 100 but then why is the memory frequncy 400mhz?
I tried to set the FSB to 166 but I got no video again, grrrr. :confused:
Correct me if'n Im wrong but ur in the wrong area there for your CPU settings... thats memory stuff!
Tried this
Lost video upon reboot. :(
Guess I'll just sleep on it.
Try leaving the memory timings at "by SPD" and the CPU FSB at 166.
Also, there should be another place to set your FSB and stuff about the CPU not in the "Advanced Chipset" section. I forget what its called though. Check to see if it allows multiplier adjustments and that it is correct for your CPU.
I got it working, I put in a different stick of ram messed around in the BIOS and got it working with that stick. Then I put the other memory back in and it worked fine. I dunno what the problem was. No my only problem is that I have out coming out of the front ports but not the rear.
