mwin
- Jun 24, 2004
I threw together a system a couple of months ago pretty quick, just to get it up and running for a get-to-gether and just recently got around to pulling it apart to put it together right. My fill line was kindof flopped over and water sat on the DangerDen fillport most of the time. It took some real effort to get the plug to unscrew out of the fillport, and I found that it was all rusted.
Are the fillports not supposed to contact the water? I was planning on throwing one in another computer as a drain port, but now I'm reconsidering. Should I change my coolant (add antifreeze, or something)?
Also, the tubes were coated in a light green something. I'm guessing that the inside of my radiator and cpu block are too. Should I worry about trying to clean them out? Or should I just leave them?
