Hi everyone. This is the second revision of...
Russs Official Guide to Buying a Computer with General [H]ardware
Recently, I have been making a lot of scattered posts here in General Hardware, commenting on various peoples attempts at picking out DIY (Do It Yourself) computers. In this thread, I am going to centralize all the advice and good deals that I came across. I am also going to point out all of the mistakes that I have seen, and save everyone a little time, trouble, and money. I may miss some things, and if you see a component you think should be included, please feel free to tell me.
The main internet retailers that I will be taking my prices from are the Big Three: Newegg, Zip Zoom Fly, and Monarch Computers. These three e-tailers are regarded as being very dependable, and all have their strengths.
This guide will start off with some general possibilities for all the parts in your home built computer. Next, I am going to branch off into budget-limited guides, covering several different levels of spending and habits. Lastly, I will try to explain my reasoning for the hardware that I have selected. Lets get started!
Note: If you want to skip to a certain section, press Ctrl + F and enter the number of the section enclosed with parentheses. Example: searching for ( 7) without that space and pressing enter twice would bring you to the Hard Drive section.
Table of Contents.
I. The Catalog
(1) Processor (CPU)
(2) Memory (RAM)
(3) Graphics Card (GPU)
(4) Motherboard (mobo)
(5) Case
(6) Power Supply (PSU)
(7) Hard Drive (HDD)
(8) Additional Cooling
(9) Keyboard
(10) Mouse
(11) Speakers
(12) Monitor
(13) Operating System (OS)
(14) Optical Drives (DVD/CD Burners)
(15) Floppy (FDD)
(16) Other Accessories
II. Preconfigured DIY Computers: Budget Builds
(B0) Section Introduction
(B1) $650 for Budget Non-Gamer any or no OC
(B2) $750 for Budget Gamer with any OC
(B3) $1,000 for Low End Gamer with any OC
(B4) $1,000 for Low End Gamer with no OC
(B5) $1,500 for Mid Range Gamer with any OC
(B6) $1,300 for Mid Range Gamer with no OC
(B7) $1,800 for High End Gamer with high OC
(B8) $2,000 for High End Gamer with little or no OC
(B9) $2,500 for SLI High End Gamer with high OC
(B10) $2,500 for SLI High End Gamer with little or no OC
III. Discussion of Catalog and Budget Builds
(C0) The Catalog
(C1) The Computers
(1) Processor (CPU)
I will not be using any Intel processors for the moment.
1. Retail AMD Sempron 2200+
Price: $63.00
Shipping: $0.99
Core: Thoroughbred B
Stock Speed: 4.5 x 333Mhz for 1.5Ghz
Pros: Cheap, T-bred B core so should OC well.
Cons: Very budget, so doesnt have the performance people might desire.
2. OEM AMD Athlon XP-M 2400+
Price: $81.00
Shipping: $1.99
Core: Barton
Stock Speed: 6.5? x 266Mhz for 1.8Ghz
Pros: VERY good OCing, Unlocked multi. Cheap.
Cons: Not many. Limited performance overall simply because it starts low.
3. OEM AMD Athlon 64 3000+
Price: $119.95
Shipping: $0.00
Core: Venice
Stock Speed: 9 x 200Mhz for 1.8Ghz
Pros: Cheap, good performance for the price. Overclocks well.
Cons: If you dont overclock, you may not get the performance you desire. Also, may require watercooling to reach the overclocked speed of other Venice cores.
4. Retail AMD Athlon 64 3200+
Price: $190.00
Shipping: $0.00
Core: Venice
Stock Speed: 10 x 200Mhz for 2.0Ghz
Pros: Overclocks well with inexpensive cooling. Not too expensive.
Cons: Much more expensive than the deal on the 3000+ because the 3000+ is supposed to be $150. May not be worth it to pay an extra 60% for the 10x multiplier.
5. Retail AMD Athlon 64 X2 4200+
Price: $525.00
Shipping: $0.00
Core: Manchester
Stock Speed: 11 x 200Mhz for 2.2Ghz
Pros: Least expensive Dual-Core CPU. Will overclock the most with adequate cooling.
Cons: Much more expensive than most single core processors. Will be eclipsed in value by the upcoming 3800+ X2.
6. OEM AMD Athlon 64 X2 4400+
Price: $615.00
Shipping: $6.80
Core: Toledo
Pros: Less than $100 more than the 4200+ X2. 1MB cache in each core.
Cons: Same speed as the 4200+ but more money. Expensive.
7. OEM AMD Athlon 64 X2 4800+
Price: $950.00
Shipping: $5.90
Core: Toledo
Stock Speed: 12 x 200Mhz for 2.4Ghz
Pros: Arguably the best stock CPU released right now.
Cons: Expensive. Wont overclock much farther than other X2 processors.
(2) Memory (RAM)
There wont be many choices in this section. If you read the guides that people like (cf)eclipse have written about Athlon 64s and memory, you will know that your timings and memory speed dont matter. Now heres the memory:
1. Crucial Value DDR400 512MB
Price: $45.00
Shipping: $3.83
Pros: Tightens its timings and OCs like a champ.
Cons: Value series, so performance may vary more than usual from buyer to buyer. Only 512 MB.
2. Crucial Value DDR400 1024MB
Price: $106.00
Shipping: $3.83
Pros: Tightens its timings and OCs like a champ. Large capacity.
3. Mushkin Speed Premium DDR400 1024MB
Price: $89.95
Shipping: $3.83
Pros: Cheap. Might be the same chips (and therefore have the same OC results) as Crucial Value.
Cons: Unconfirmed by any buyer that these are the same as Crucial Value.
For the Brief Specs section, the first two numbers are the GPU core clock and the Memory clock (core/memory). Then comes the memory size and interface (#Mb #bit). Then the memory type (example: GDDR3) and finally the interface (PCI-E or AGP).
1. Rosewill 9200SE
Price: $37.99
Shipping: $4.99
Brief Specs: 200/333 128mb 64bit DDR AGP
Pros: Cheap, good for non-gaming applications
Cons: DX8, so if you want to game, get the 9800 pro.
2. MSI 9800 pro
Price: $99.00
Shipping: $1.00
Brief Specs: 378/676 128mb 256bit DDR AGP
Pros: Cheap. Might flash to 9800XT.
Cons: Refurb. It is $120 (+$4.99 shipping) new here
3. XFX 6600GT
Price: $160.00
Shipping: $0.00
Brief Specs: 500/1000 128mb 128bit DDR3 PCI-E
Pros: Good budget PCI-E card. Has DDR3.
Cons: Slightly more expensive than it used to be (but more expensive everywhere).
4. 6800NU (Non Ultra)
Price: $188.00
Shipping: $0.00
Brief Specs: 325/700 128mb 256bit DDR AGP
Pros: Unlockable Pixel Pipelines/Vertex Shaders. Good performance for the money.
Cons: Unlocking might not work.
5. Connect3D X800 XL
Price: $259.00
Shipping: $0.00
Brief Specs: 400/980 256mb 256bit GDDR3 PCI-E
Pros: 256mb GDDR3 ram, good price.
Cons: Not many. 6800GT possibly a better value. No dual video card option right now.
6. XFX 6800GT
Price: $296.00
Shipping: $5.00
Brief Specs: 350/1000 256mb 256bit GDDR3 PCI-E
Pros: Good value. Great price! Can do SLI.
Cons: $50 Mail-In Rebate.
7. eVGA 7800GTX
Price: $500.00
Shipping: $7.70
Brief Specs: 450/1200 256mb 256bit GDDR3 PCI-E
Pros: Cheapest 7800GTX from the Big Three. Comes with BF2. Step-up program.
Cons: Not the highest clock.
8. XFX 7800GTX
Price: $545.00
Shipping: $0.00
Brief Specs: 490/1300 256mb 256bit GDDR3 PCI-E
Pros: Fastest clocked 7800GTX.
Cons: Slight price premium for something an overclocker could do himself or herself. Not much in the way of extras.
One low end, then modern non-SLI and SLI of OCing and non-OCing versions about sums up this section.
1. Biostar M7NCD Ultra nF2
Price: $52.00
Shipping: $2.50
Features: 1 AGP 4x/8x slot, DDR, SATA, socket A
Pros: Cheap, reportedly good Ocing
Cons: Outdated (sA and AGP), capacitors reportedly close to CPU socket
2. DFI nf4-DAGF
Price: $89.00
Shipping: $0.00
Features: 1 PCI-E 16x slot, NO SLI
Pros: Cheap, has the well-known DFI Overclockability, including the high RAM voltage.
Cons: Not as stable as some boards at stock speeds.
3. DFI Lanparty UT nf4 SLI-DR
Price: $165.99
Shipping: $2.50
Features: 2 PCI-E 16x slots, SLI
Pros: SLI. And of course lots of OCing because its DFI.
Cons: Price to an extent. Also not as stable as some boards if at stock settings.
4. Asus A8N-E
Price: $113.99
Shipping: $0.00
Pros: Stable non-SLI board. Asus will replace chipset fan free.
Cons: Chipset fan might act up. Not as good for OCing as DFI. Slightly expensive compared to DFIs offering.
5. Asus A8N-SLI
Price: $135.99
Shipping: $0.00
Pros: Stable SLI board. Cheap SLI! Asus will replace chipset fan free.
(5) Case
A case is largely a personal choice. I find it hard to recommend a particular case for someone. Good things to look for are 120mm fans in the front and back, a window if you want on, and side and top fans if you want them. Saying that, here are a few cases you might be interested in (I still want you to look for your own).
1. Antec Sonata
Price: $68.99
Shipping: $12.99
Features: Black, 120mm fan rear, 120mm empty fan slot front
Pros: Cheap, for now! VERY quiet.
Cons: $30 Mail-In rebate. Limited time MIR offer! You are paying for a PSU too though.
2. Antec SLK1650B
Price: $65.00
Shipping: $15.99
Features: 350W Antec PSU, 120mm rear fan, 120mm empty fan slot front
Pros: Cheap for a case AND a good PSU.
Cons: ATX mobo is hard to fit in, but can be done (suggestion made of temporarily removing HDD case)!
3. Antec SLK3000B
Price: $46.00
Shipping: $15.99
Pros: Cheap! Will be a good buy once Sonata MIR expires. Same case as Sonata but with different front bezel and no PSU. Quiet.
Cons: Front bezel regarded as flimsier, looks worse than the Sonatas.
4. Lian Li PC-6077B
Price: $121.50
Shipping: $15.99
Features: Black. Three 80mm fans included (Two in back, on in front).
Pros: Not too expensive for a Lian Li! Available for $16.50 less in a Silver version. Front drive bays can be removed (more on that later).
Cons: Out of Stock at the moment. No 120mm fans. No window (could be bad or good).
5. Cooler Master Stacker
Price: $158.99
Shipping: $16.45
Features: Eleven drive bays (removable). 120mm front and rear fan. 80mm top fan. Available in black (-$1.20 shipping). Cross flow fan can also be purchased for $32.99.
Pros: Big. Lots of Air flow. Can fit up to 3 120mm fans in front. Two PSU slots (top and bottom). E-ATX and BTX compatible.
Cons: Big. No fancy exterior (good or bad). Drive bays exposed.
6. Cooler Master Stacker 810
Price: Unreleased (Scheduled for Late July)
Shipping: Unreleased
Features: 2 rear 120mm fans and 120mm front fan and 80mm Top fan. 11 Drive bays. Black.
Pros: 2 rear 120mm fans. First of its kind! Can fit up to 3 120mm fans in the front.
Cons: Unreleased. No fancy exterior (good or bad). Exposed Drive bays. No longer has two PSU slots.
7. Gigabyte 3D Aurora
Price: Unreleased (Scheduled for August)
Features: 2 rear 120mm fans and 120mm front fan. See a review here.
Pros: 2 rear 120mm fans. First of its kind! Sleek silver exterior. Customizable lighting in front (projects image). Rubber mounted watercooling tubing holes in rear.
Cons: Unreleased.
Only three for now. If you want another to be put up, ask.
1. Antec TruePowerII TPII-430
Price: $69.99
Shipping: $6.99
Stats: 430W, single fan (120mm?), >70% efficiency. 12v@34A
Pros: Cheap, 24 pin, high 12v rails. Single fan.
Cons: Wattage low, or maybe Im just spoiled by Seasonic.
2. Aerocool Turbine Power 550W
Price: $99.99
Shipping: $0.00
Stats: Modular, 550W.
Pros: Cheap for the wattage. HIGH 12v rails (20A and 18A).
Cons: Aerocool not as well known for PSUs as Antec, Enermax, etc.
3. Seasonic S12-500
Price: $105.00
Shipping: $7.00-$12.00 (varied)
Stats: 500w, single 120mm fan, ~80% efficient. 12v@36A
Pros: Quiet, efficient, powerful 12v. Cheap.
Cons: None. Maybe a little watt starved in very power hungry SLI systems.
4. Seasonic S12-600
Price: $130.00
Cons: None. A little overkill in low-power, non-SLI systems.
Simply put, these are the only hard drives Id ever buy unless I needed SCSI. Just get the one that suites your price and storage needs.
1. Maxtor DiamondMax 10
Prices:
$155.00 for 300GB
$114.00 for 250GB (Best Value)
$97.50 for 200GB
Shipping: $0.00
Interface: SATA150
Stats: 7,200 RPM; 16 MB Cache, 3 year warrantee.
Pros: Fast (thanks to cache), large storage capacity, cheap (just as expensive as 8mb drives).
Cons: None. You can pay for the MaxLine III version and get a 5 year warrantee if you want..
2. Maxtor DiamondMax 10
Prices:
$162.00 for 300GB
$115.00 for 250GB (Out of Stock)
$104.00 for 200GB (Out of Stock)
Shipping: $0.00
Interface: Ultra ATA133
This section is quite disorganized. Fans, air CPU cooling, and water cooling all go into this thread. I hope you can excuse me for just dumping a few links in here for now (and not all of the ones I want to give you yet), but I have to finish up, so this is all you get for now. Ill tidy it up later. O, and shipping isnt included with the watercooling. Sorry! I have to think of another way to present it.
1. Panaflo M1A 120mm fan
2. Thermalright XP-90 w/ Panaflo 92mm Med. & AS Ceramique $38.94
3. water cooling:
CPU Block and Pump: DD TDX and DD12V-D5 combo $108.75
GPU Block: Low Profile Maze4 $46.45; . 8 BGA Copper RAMsinks $9.95
Radiator: Black Ice Pro II $35.99; . Panaflo 120mm M1A $9.75 x2 = $19.50; . Radiator Mounting Kit $4.95
Reservoir: CrazyPC single 5 1/4" bay $15.99
Tubing: Tygon 3/8" ID 9/16" OD 10 ft x $1.95 = $19.50
Fittings: 1/4 NPT Fittings for 3/8" ID tubing $1.00 x 4 = $4.00; . Polypropylene "Elbow" 2 x $1.75 = $3.50
Clamps: Metal Worm Clamps buy at hardware store
Other: MCT -40 water additive $0.00 (gift w/ >$100 order); . 6" Velcro $2.49 x 2 = $4.98
watercooling total: $273.56
Table of Contents.
I. The Catalog
(1) Processor (CPU)
(2) Memory (RAM)
(5) Case
(9) Keyboard
(10) Mouse
(11) Speakers
(12) Monitor
(15) Floppy (FDD)
(C0) The Catalog
(C1) The Computers
(1) Processor (CPU)
Price: $63.00
Shipping: $0.99
Price: $81.00
Shipping: $1.99
Core: Barton
Price: $119.95
Shipping: $0.00
Core: Venice
Price: $190.00
Shipping: $0.00
Core: Venice
Price: $525.00
Shipping: $0.00
Core: Manchester
Price: $615.00
Shipping: $6.80
Core: Toledo
Price: $950.00
Shipping: $5.90
Core: Toledo
(2) Memory (RAM)
Price: $45.00
Shipping: $3.83
Price: $106.00
Shipping: $3.83
Price: $89.95
Shipping: $3.83
1. Rosewill 9200SE
Price: $37.99
Shipping: $4.99
2. MSI 9800 pro
Price: $99.00
Shipping: $1.00
3. XFX 6600GT
Price: $160.00
Shipping: $0.00
Price: $188.00
Shipping: $0.00
Price: $259.00
Shipping: $0.00
6. XFX 6800GT
Price: $296.00
Shipping: $5.00
7. eVGA 7800GTX
Price: $500.00
Shipping: $7.70
8. XFX 7800GTX
Price: $545.00
Shipping: $0.00
Price: $52.00
Shipping: $2.50
2. DFI nf4-DAGF
Price: $89.00
Shipping: $0.00
Price: $165.99
Shipping: $2.50
4. Asus A8N-E
Price: $113.99
Shipping: $0.00
5. Asus A8N-SLI
Price: $135.99
Shipping: $0.00
(5) Case
1. Antec Sonata
Price: $68.99
Shipping: $12.99
2. Antec SLK1650B
Price: $65.00
Shipping: $15.99
3. Antec SLK3000B
Price: $46.00
Shipping: $15.99
4. Lian Li PC-6077B
Price: $121.50
Shipping: $15.99
Price: $158.99
Shipping: $16.45
Cons: Unreleased.
Price: $69.99
Shipping: $6.99
Price: $99.99
Shipping: $0.00
3. Seasonic S12-500
Price: $105.00
4. Seasonic S12-600
Price: $130.00
Prices:
$155.00 for 300GB
$97.50 for 200GB
Shipping: $0.00
Interface: SATA150
Prices:
$162.00 for 300GB
Shipping: $0.00
3. water cooling:
