Flow rate doesn't matter so much. It might hurt your temps a smidge compared to a stronger pump with the same setup but it really depends on the entirety of the loop.
Shouldn't be a problem. I've run two radiators using a single MCP355 without issue. Flow should suffer much, and you can run your fans at a lower RPM depending on your setup. Go for it.
