Running two different clients at the same time
Lengradde
I have a 2500k sandy bridge CPU, and ATI 6850 GPU.
I want to run folding@home with my 2500k, and milkyway@home with my 6850, though I realize milkyway will still require some CPU usage.
I currently have SMP on the F@H client set to run on 3 cores.
On BOINC for milkyway@home, I have changed the following two settings:
On multiprocessor systems, use at most 25% of the processors.
Use at most 25% CPU time.
Haven't touched any of the other settings for BOINC. It doesn't seem like milkyway is even using my GPU.
Am I even doing this right? I'd really like to be using my 6850 for something! I'm such a newbie to this. :D
its possible but milkyway requires a double precision card and the 6800's aren't double precision, so collatz would be the only thing you can run.
Thank you, currently running collatz now.
I was getting about 10,500 PPD with my 2500k@4.3ghz. I'm still tweaking how much CPU power collatz uses and right now it is set to use only 10% CPU time. Currently I'm only losing about 800 PPD in F@H by running collatz.
Depending on how much CPU power is required by whatever DC project you use on the GPU, you might be able to get away with running F@H on all four cores.
