Running two clients
Pooch666
I'll be damned if I can figure out how to run 2 clients at the same time. I have the GPU client installed running a 8800GS and it works fine. What do I have to do to get the old systray CPU client running in tandem? :confused:
Thanks, Gary
That's very easy, just install the CPU client in another folder then when you configure it (with the -configonly), make sure you set a different MachineID. However, the GPU client is set to use MachineID of 2 by default while the CPU client use 1.
