Ok I have what i'm sure is a dumb question about running pumps in series. I understand how running pumps in series works.
Res>pump1>pump2>rest of the loop.
But my question is about running them in series using a dual bay res like the koolance 402x2 or the XSPC dual ddc. With a res like the 2 above, Wouldnt it be Res1>pump1>Res2>Pump2>rest of the loop? Does it not matter that the Res is in between? I don't think you can bypass the res on either model so does one res just stay filled under pressure from pump1, then that res feeds into pump2?
