Running Gsync do i disable Vsync now.
Marcdaddy
I noticed that in my Control panel I have Gsync enabled with the default having Vsync enabled as well. Is it preferred to turn Vsync off? Doesn't it introduce lag? Thanks guys, id rather have input here then from GOOGLE searches. Im using a Acer Predator X34 and loving it so far.
Disable V-Sync in the game to activate G-Sync.
V-Sync in the driver controls what happens when the framerate goes above the monitor's refresh rate.
No, V-Sync will not kick unless the framerate goes outside of G-Sync's range.
Disabling V-Sync on the control panel definitely introduced tearing when my game was running on 30fps, so I left it on. I have never tried disabling V-Sync on the control panel when the fps was in G-Sync range though.
