Running Dual Monitors on Crossfire.
the gamer
I just want to clear up something,
Would the cards disable crossfire when not in a 3d program and and enable the second monitor?
and when you play a game will the cards disable the second monitor and turn crossfire on the main monitor etc etc?
Hope this sounds right, and would crossfire be turned back on if I were to use 3ds Max (Direct X 9 Mode)
Thanks
I believe CF works the same way as SLI, in that you have to enable and disable it through the drivers every time. I could be wrong about that, since I'm just going by what I've read.
r I hope ATi puts a feature it so it does it automatically but if I have to do it manually then so be it I guess, though by the time I upgrade again there should be a feature like that.
