Running dual monitors in different resolutions?
FlashFunk
Two Questions:
1. Is this possible? I would be using a 8800 gts. For instance can i have one monitor running at 1600x1200 and another running in a wide screen resolution? If this is possible, would there be performance issues.
2. With the same card above, can I be playing WOW in one monitor, while browsing the web in a second by just moving the cursor between monitors. Again, would there be any performance issues, and would this require me to play in windowed mode?
you need windowed mode to go back and forth in the game.
Different resolutions are fine.
