Running dual monitors hurt framerates?
oceancyc
Will running my ATI Radeon 9800 Pro with both the VGA and TV out display hurt my frames when playing games like UT2K4? I usually keep them both going at the same time.
slightly...when the secondary display is enabled, the GPU will at least dedicate part of the video memory for buffer and etc...not much...depends on how the game is programmed.. Do expect about 10-20% frame drop.
I've never had any conflicts with dual monitors, or framerate hits. Though, every now and then you might have a game where the cursor glitches and sometimes slips to the other screen.
Also, installed ati hyrdavision. It has a nifty feature where you can rightclick on an icon and select save icons. Then if any game screws up your icons, or you have to temporarly turn off the 2nd display for a particular game, you then right click on any icon and select restore icons and they all go back to where they were.
