long story short.
new construction, our building on our property
3rd party entity will occupy and have use of facility during weekends, while we have use during weekdays.
Because of 2 separate entities occupying the building we are pulling drops to IDF's, and both of our organizations will put in our own switches. Effectively 2 separate networks.
All our IDF's are usually interconnected by fiber, with a 25 pair 66 block pulled back from each IDF into our MDF core.
If copper connectivity is needed for something you just punch down on the 66 block however many pairs you need. easy.
However this entity has some kind of video system that is using copper as its transport medium. whatever. They want copper punched down on the patch panels, and then connect to other IDF's (not the MDF) in this new building. (a total of 3 new IDF's are being built as part of this new building)
I've not typically seen this method of inter-connectivity but they tell me they do it all the time. This is technically our building so I'm not sure if this is a battle I want to fight. Has anyone does this type before?
Ideally I'd like to tell them to just use our 25 pairs and tell them they need to figure it out. But that might piss them off and they might take things to the higher ups.
