I'm looking to set up a HTPC in my basement and run a HDMI cable, a USB extension and network line (pretty much directly above the HTPC) into a keystone wall plate behind my living room TV. Right now the coax comes up thru the floor in the living room, so in the process of running these lines I'm also going to clean up some coax runs in the basement and run a new coax line to the same keystone wall plate.
So I'm just wondering if there will be any issues with running / bundling these 4 cables together as they run up from the basement, between the wall and into the back of the wall plate?? I think coax needs to be run away from electric lines, but I wasnt sure if any of these other lines would interfere with each other??
