Is it ok to do this? Or what can I do to help shield the wire?
This is really the only way I can run the cat 6 without getting into some major work... the holes and path are already there to run exactly where I want it to - around the outer wall of my condo.
For most of the way, it will be fine, 2-3 inches away etc. but through the walls, the passageways get a little tight... and the pipes get hot.
Any ideas?
Any ideas?
