- May 18, 1997
That test is complete shit and comparing a single result will tell you NOTHING. I have seen minimum frame rate values change over 30% from test to test.Whoever did that test is looking at entirely the wrong thing.
Minimum framerates have gone up significantly in DX12.
Benchmarks run on a 6600K with a 390X:
So is DX11 is better than DX12 based on that benchmark?
Look at the minimum framerates. In DX11 it drops to 9.32 FPS, while in DX12 the lowest is 30.76 FPS!
That is far more important for a fluid gameplay experience than an average drop of ~7 FPS.
It could still be better optimized, because there shouldn't really have been a performance drop at all, but it's still a huge improvement.
Async Compute is a big deal looking forward, and NVIDIA is going to have problems if Pascal does not support it.
That said, I won't be switching to AMD until they sort out their DX11 performance.
Without driver command list support, their DX11 driver is single-threaded and performance is considerably worse than NVIDIA as a result.
So for me it really depends who gets there first: AMD with properly multi-threaded and well-optimized DX11 drivers, or NVIDIA with Async Compute.
Unfortunately I suspect that means I'll be holding onto my 960 for another generation instead of upgrading this year.
