RancidWAnnaRIot
EspantaPajaros
- Feb 19, 2004
Hello,
I just got finished lapping a heat sink (pretty damn shiny too
) .. anyway.. i was just wondering.. has anyone ever tried using rubbing compound on a heatsink?? would it screw up the heat sink?? i figure it would cause the compound can get in the little cracks on the heat sink and screw the heat sinks ability to transfer heat... anyway, i just wanna see if anyone has actully tried it..
Thanks,
Thanks,
