Rubber O-rings?
bladeiai
Hi I am upgrading my system and thought I would redo my loop while I was at it, so anyways I'm noticing the rubber o-rings that go between the block and 1/2" fitting are starting to get cracks in them like they are breaking down/drying out.
Does anyone know where you get get just the rubber O-rings? I've looked on lots of sites but cant seem to find them.
Thanks
A local scuba shop. If nothing else you can take in one of your o-rings and size it to find out what ones you need from McMaster, etc.
Orchard Supply has the most o-ring assorts from a local store. I was able to find them there after not seeing them at Lowe's and Home Depot. The only problem is that Orchard Supply isn't located everywhere.
