Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
It might, but even if the case bottom is on the carpet you will be find as long as you remember to ground yourself when you work on your computer. Grounding yourself when working on computers is common sense, and as long as you do that you should be fine
All static from the plastic case feet and the carpet should go straight to the frame of the case (which is grounded by the PSU) so that shouldn't really be a problem
