RTX 5090 failures
Pinch of salt.
Like with 3090 and 4090, the amount of clearly first time GPU (seemingly custom PC in general) buyers i've encountered that somehow got their hands on a 5090 and are asking questions across various forums and discords, I'm never surprised to see things like this straight after a launch.
I am not sure how-why a first time buyer would be that relevant here, if anything are they not more likely to simply just use the standard nvidia driver updater they downloaded from Nvidia than trying anything fancy ?
When I tried to reinstall the new driver after putting the card in, my whole system went black during driver reinstall. I had to reinstall windows completely to get back in. I thought for sure the card was DOA.
i saw that in your other thread. a new gpu should not require a windows reinstall. did you remove the driver first or were you just trying to reinstall over top for some reason? if the current driver is installed you should only have to remove the old card from device manager, shutdown, install new, power up and reboot a couple times.
It was a clean reinstall that just failed. A first for me. I was kind of shocked. I'm guessing this driver will be replaced by NVIDIA quickly.
so you were trying to install the 5090 driver over the older one with the "clean" option and it went black? DDU via safe mode probably would have sorted that out, rather than rebuilding windows.
Historically it’s been shitty testing and qc of designs, not first time or low experience builders. Anyone can read and follow instructions.
Always remove the old video card from the device manager before installing the new one. I would use Display Driver Uninstaller to make sure the old driver and HIDs are completely gone. I've absolutely no doubt that this is the cause of the issues people are having. I have no idea when or where the concept of not needing to uninstall the old video card started.
ive never had that "clean" option work proper on nvidia or amd's side... well, at least its up and running now!
All the "clean" install option does is remove the saved settings in the driver control panel, resetting them to default. It isn't "clean" in the sense that it will overwrite device-specific flags.
ah, that would be why it doesn work the way i expected then. im still in the old habit of using ddu first for anything to do with the gpu....
From what I've seen, i'm firmly of the opinion that many failures are due to clueless first time owners. I was just today helping what sounded like a kid plug in his new 5090, he had zero concept of power supplies, the cables needed to properly connect it or the last two years of history surrounding what can go wrong if you can't figure out how to plug in a cable.
