I cleared the real time clock in cmos and now it won't retain info, I need the overdrive fearture set on standard so I can use my video card. anyone know how to fix?
P.S. - I changed the battery and the jumpers on the board are all in the same place
How did you clear the RTC? Is there any way to set it back to a normal number? Do you have access to any other PC that you can borrow a floppy drive from? Chances are you can reflash the BIOS with a diskette. A BIOS reflasher and a BIOS binary (.bin) should be available on the website of the board manufacturer.
