Hwody, I've got a T1 to my office with a Pix506E running firewall duties. Our VPN network topology is hub and spoke with the Office being the hub and 11 spokes with IPSEC VPN's to some linksys BEFVP41 routers. We also have 8 users randomly using the Cisco Software VPN client as well. I need to be able to route traffic between all spokes as well as the software client. As it sits now, Traffic from the spokes and the Cisco client stop at the office. Is this possible with a Pix?
Current config...
PIX Version 6.2(3)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ********* encrypted
passwd ********* encrypted
hostname ******
domain-name ******
clock timezone CST -6
clock summer-time CDT recurring
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
fixup protocol sip udp 5060
names
object-group network StoreVPN
network-object 192.168.50.0 255.255.255.0
network-object 192.168.52.0 255.255.255.0
network-object 192.168.53.0 255.255.255.0
network-object 192.168.55.0 255.255.255.0
network-object 192.168.56.0 255.255.255.0
network-object 192.168.58.0 255.255.255.0
network-object 192.168.60.0 255.255.255.0
network-object 192.168.61.0 255.255.255.0
network-object 192.168.62.0 255.255.255.0
network-object 192.168.71.0 255.255.255.0
network-object 192.168.72.0 255.255.255.0
object-group service sip tcp-udp
description sip
port-object range 5060 5060
port-object range 5004 5004
object-group network CiscoClient
network-object 10.1.1.0 255.255.255.0
access-list outside_in permit icmp any any echo-reply
access-list outside_in permit icmp any any unreachable
access-list outside_in permit icmp any any time-exceeded
access-list outside_in permit icmp any any source-quench
access-list outside_in permit tcp any host **External IP** eq www
access-list outside_in permit tcp any host **External IP** eq pop3
access-list outside_in permit tcp any host **External IP** eq 5900
access-list outside_in permit tcp any host **External IP** eq smtp
access-list outside_in permit tcp any host **External IP** eq 17888
access-list outside_in permit tcp any host **External IP** eq 9008
access-list outside_in permit tcp any host **External IP** eq ftp
access-list outside_in permit tcp any host **External IP** eq pcanywhere-data
access-list outside_in permit tcp any host **External IP** eq 5632
access-list outside_in permit tcp any host **External IP** eq 11999
access-list outside_in permit tcp any host **External IP** eq 11998
access-list split-tunnel permit ip 10.0.0.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip any 10.1.1.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.55
.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.50
.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.52
.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.53
.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.56
.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.58
.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.60
.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.61
.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.62
.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.72
.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 10.0.0.0 255.255.255.0 192.168.71
.0 255.255.255.0
access-list outside_inbound_nat0_acl permit ip object-group CiscoClient object-g
roup StoreVPN
access-list outside_inbound_nat0_acl permit ip object-group StoreVPN object-grou
p CiscoClient
access-list nate_splitTunnelAcl permit ip 10.0.0.0 255.255.255.0 any
access-list Tammy_splitTunnelAcl permit ip 10.0.0.0 255.255.255.0 any
access-list Brian_splitTunnelAcl permit ip 10.0.0.0 255.255.255.0 any
access-list Dispatch_splitTunnelAcl permit ip 10.0.0.0 255.255.255.0 any
access-list Amy_splitTunnelAcl permit ip 10.0.0.0 255.255.255.0 any
access-list Karen_splitTunnelAcl permit ip 10.0.0.0 255.255.255.0 any
access-list Sarah_splitTunnelAcl permit ip 10.0.0.0 255.255.255.0 any
access-list 58_splitTunnelAcl permit ip 10.0.0.0 255.255.255.0 any
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside **External IP** 255.255.255.252
ip address inside 10.0.0.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpn-pool 10.1.1.1-10.1.1.254
pdm location 10.0.0.0 255.255.255.0 outside
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (outside) 0 access-list outside_inbound_nat0_acl outside
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface www 10.0.0.2 www netmask 255.255.255.255 0
0
static (inside,outside) tcp interface pop3 10.0.0.2 pop3 netmask 255.255.255.255
0 0
static (inside,outside) tcp interface 5900 10.0.0.2 5900 netmask 255.255.255.255
0 0
static (inside,outside) tcp interface smtp 10.0.0.2 smtp netmask 255.255.255.255
0 0
static (inside,outside) tcp interface 17888 10.0.0.9 17888 netmask 255.255.255.2
55 0 0
static (inside,outside) tcp interface 9008 10.0.0.9 6129 netmask 255.255.255.255
0 0
static (inside,outside) tcp interface ftp 10.0.0.2 ftp netmask 255.255.255.255 0
0
static (inside,outside) tcp interface 17889 10.0.0.9 17889 netmask 255.255.255.2
55 0 0
static (inside,outside) tcp interface 11999 10.0.0.103 3389 netmask 255.255.255.
255 0 0
static (inside,outside) tcp interface pcanywhere-data 10.0.0.18 pcanywhere-data
netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 5632 10.0.0.18 5632 netmask 255.255.255.25
5 0 0
static (inside,outside) tcp interface 11998 10.0.0.107 3389 netmask 255.255.255.
255 0 0
access-group outside_in in interface outside
route outside 0.0.0.0 0.0.0.0 **T1 Router IP** 1
timeout xlate 8:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
no sysopt route dnat
crypto ipsec transform-set strong-des esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set test1 ah-md5-hmac esp-3des esp-md5-hmac
crypto dynamic-map dynmap 4 set transform-set strong-des
crypto dynamic-map inside_dyn_map 30 set pfs group2
crypto dynamic-map inside_dyn_map 30 set transform-set ESP-3DES-SHA ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 10 set transform-set strong-des
crypto dynamic-map outside_dyn_map 10 set security-association lifetime seconds
3600 kilobytes 4608000
crypto map partner-map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map partner-map client configuration address respond
crypto map test 10 ipsec-isakmp dynamic outside_dyn_map
crypto map test interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 7200
vpngroup nate address-pool vpn-pool
vpngroup nate dns-server 10.0.0.9
vpngroup nate wins-server 10.0.0.1
vpngroup nate default-domain LLOC
vpngroup nate split-tunnel nate_splitTunnelAcl
vpngroup nate idle-time 1800
vpngroup nate password ********
vpngroup Dispatch address-pool vpn-pool
vpngroup Dispatch dns-server 10.0.0.9
vpngroup Dispatch wins-server 10.0.0.1
vpngroup Dispatch default-domain LLOC
vpngroup Dispatch split-tunnel Dispatch_splitTunnelAcl
vpngroup Dispatch idle-time 1800
vpngroup Dispatch password ********
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 10
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
vpdn enable outside
terminal width 80
Cryptochecksum:d863e95c3fd3dc4e06c1698ccd396243
: end
Any ideas?
Current config...
PIX Version 6.2(3)
hostname ******
domain-name ******
names
description sip
.0 255.255.255.0
.0 255.255.255.0
.0 255.255.255.0
.0 255.255.255.0
.0 255.255.255.0
.0 255.255.255.0
.0 255.255.255.0
.0 255.255.255.0
.0 255.255.255.0
.0 255.255.255.0
.0 255.255.255.0
roup StoreVPN
p CiscoClient
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
0
0 0
0 0
0 0
55 0 0
0 0
0
55 0 0
255 0 0
5 0 0
255 0 0
http server enable
floodguard enable
telnet timeout 10
ssh timeout 5
vpdn enable outside
terminal width 80
: end
Any ideas?
