- Feb 8, 2005
I've got a Comcast business connection with a static IP that I'm finally getting around to setting up. On my old connection, I used the modem as a gateway and set up port forwarding. There was only 1 static IP assigned. It was assigned to the modem. Everything worked, and the world was good. On the new connection, the same setup works, but my gateway IP and my assigned static IP are different. I suppose my external gateway IP could change one day. Am I supposed to plug in a device of my choice into the modem, assign it the static IP I was given, and route my traffic through there instead? Like... Without NAT?
tl;dr: External gateway IP and assigned static IP do not match. What do?
